Just to report, as i got it fixed.
Webaccess (LAN)
resulted in a white page.
Tried Chrome, Safari on iPad and Windoze with Edge and Firefox.
Yubi app working normally.
Access was eventually obtained via
Not all menu items worked in the interface
Reboot was tried, power off / on with the powercord. None helped.
Via the backup interface recovered (rollback) with version to 5.131.57.
Re-installed to beta 5.132.9.
To get all to work after installing 5.132.9 again, on Safari and chrome mobile clearing of cache was needed.
Did you clear your cache at first instance ?
I have an opened ticket about similar issues, however, for me the web access used to start working after about 5-6 min. I am doing nothing, just waited for a few minutes. Didnt get answer why it happens.
On very first place i got some suggestions, that maybe i should reset network settings on the hub, or double check if there is no other network in my house. Maybe you should try these steps too.
Resetting the network can be done by pressing and holding the + button on the hub, while the internet led diod will start flashing..
So these are some suggestions from support.
