Kobus007 2
As per a previous post it was recommended to add this device in "S0 Security mode if device supports it". Adding it like that solves the configuration problem. But no values come through then.
When I add it NWI then all value pulls through. And I can use it in scenes. The screen does however freeze up when adding it, then I have to close it and reopen. And at the end it shows as not configured.
This problem started when the system advised that there is a template available, and I changed to the template. Does anybody know how to solve the configuration problem and get the values?
/monthly_2023_02/image.png.282868cabf27b59cc0cd295673138251.png" />Have tried reconfiguring the device .. but same problem.
8 answers to this question
