I recently purchased a fibaro switch and followed the installation instructions. I think the installation is correct.
When I tested the switch, I found the following behavior.
light start off
 action -> fibaro turn on
 result  -> light on
 action -> fibaro turn off
 result  -> light off
 action -> click wall switch
 result  -> Light off ----> ????? The light should be on!!!!
 result  -> light on
 result  -> light off
 result  -> light on
 result  -> light off
 result  -> light on
 result  -> Light on ----> ??? The light should be off!!!!!
 result  -> light on
In short, after turning on/off the fibaro switch, the wall switch does not respond to the first click
Is this the expected behavior? Did I install it wrong?
Edited by Uhoyo
    Fixed.
    I need to set the switch type as "Bistable - control of the slope" in the Fibaro app.
