No response in Webapp but physical button does work
This is for a Fibaro HC2 setup.
I have a Dimmer 2 with no lamp/black wire. Instead I have connected it to a bypass. It's operated by a double impuls switch.
On S1 I have 4 other dimmers associated in group 3 and on S2 I have 2 other dimmers associated in group 5.
If I use either the Physical button s1 or S2 the associated dimmers respond correctly.
However, if I turn off or on the lights via the app or web interface nothing happens. They don't respond. Does anybody have any idea why that is?
Associations are being send only by physical interaction with the device to avoid loops and other problems.
It is like that due the Z-Wave requirements.
There was a command class for this in the past (called "Remote Associations" if I remember correctly but it is obsoleted for some time now).
