When starting the app it seems to start normal. The home screen comes up and the it's gone and the Yubii logo is shown.
This occured after today's update.
Did you already try to clear the app cache;
I have no issues on Android and IPad
    I have restarted my phone, indeed also forced a stop and cleared the cache.
    So, I guess I'm the only one...
    Hmm...I will remove the app and install again.
    Well...re-installing the app solved the issue.
    Now I have to re-configure it to my needs again.
    Btw...after using Fibaro for almost a decade, my profile is still rated as a Newbie 😄
    Thanks for the quick respons!
    You are probably new to issues, maybe otherwise you would post more questions and raise your “newbie” status.
    It didn't work for me either.
    I had to clear app data and then it started.
    No problems with the app overhere 1.18
    Same problem at my place. I had to clear the app's data to get it to stop crashing. But what the hell! I have to do all the settings of the device order again! grrr.
    I logged in locally the first time to get the icons to download as usual and it was a drama. The app took several minutes to load the icons. It was impossible to use the application. We'll see what happens next.
    The latest version of the application works very slowly in my case, in addition, I do not have a preview of the cameras because RTSP configuration is required, which my cameras do not support :(
