I‘ve updated to 5.140 - no problems encountered so far.
No problem also here.
Updated 12hrs ago and no problems.
No problem for me too, search started working faster.
Updated through the new function in the iPhone app which worked perfectly well. No issues at all seen so far.
I‘ve updated to 5.140 - Z-wave devices work without problems, but some Zigbee devices eg. Smart Power Strip ( SM-SO306-EZ) loose some functionality.
Now only one socket can be controlled, not all 4 like in 5.130.64...
Updated to 5.140 yesterday without problems, i cant even remember when update did’nt went well.
Updated 24 hours ago. All seems working good so far
Same here, no issues encountered during or after update.
Smooth update, no problems.
Nice to see a positive topic about a update :)
After upgrading to 5.140, the control panel has a problem starting up and keeps giving a message that it is starting services then reboots and tries auto-repair and so on and so forth
No problems for me too so far.
For me the update was fine but after two days the HC3 bootet into recover mode.
Also I cannot boot normally, the services are loading for about half an hour and than it boots again into recovery mode.
I did never had this problem before (beside the "automatically reboots" every two weeks (see other cases about this problem).
It is probably something with your specific configuration, you can just rollback to previous version by switching the system back to old one in recovery.
You can also contact support after that if you would like to help us resolve the issue - they will arrange remote access session and we will be able to check it out and probably find a solution really fast.
Updated to 5.140 one week ago and no problems so far 👍
