Hikvision ip camera H.264 Camera rstp in Fibaro
/monthly_2023_03/20230307114512.png.9ce5477a0d5192c772160b9a91a64eab.png" />
That should work according to Hikvision, or 102 for the second channel. But it probably depends on some setting from the camera's itself, because it doesn't work on my Hikvision camera's.
This setup works for me, maybe it works for you too...
/monthly_2023_03/image.png.1b5ddea40e05691e0cee4f234455fb77.png" />
Oh, wauw. So if you leave the RTSP link blanc, the Yubii app uses the JPG or MJPG stream?
That wasn’t the case in the earlier beta version of the Yubii app, but it would be great if it now works that way. I will give it a try.
Tried it without a RTSP link, but doesn’t work. Does it really work in your new Yubii app @ChristianSogaard?
    @SmartHomeEddyThis can be displayed in the new version of app!
    Thanks Lux, but I don't understand what can be displayed?
    @SmartHomeEddydisplay Rstp stream of surveillance camera ! This configuration is useful!
    (I think you need to setup the JPG or MJPG streams to show the video in the web user interface)
    The RTSP stream path setup doesn't work with my Hikvision camera's. I suspect some setup things of the camera's itself.
    Edited by SmartHomeEddy
    @SmartHomeEddyThat's possible. You can try to use vlc media player
    Indeed, also tried the path in VLC, but no success. That is why I suspect the camera setup. But reviewed the camera setup and haven't found a clue what it could be.
    (BTW the RTSP stream of my AVtech camera's work if I use the Yubii app on my local network, but not when I use the Yubii app via internet.)
    I use Intranet penetration!
    Edited by lux
    • 3 weeks later...
    i have the same problem, almost giving up
