After update the energie consumption is not working.
The graph in the extended tap is not showing anymore.
The lua code from swagger did not work anymore.
Could you elaborate a little all those points, we would like to know exactly when and where mentioned problems occur?
Same here … the Energy Panel, Tab General, displays: „No data to be viewd in the chart“ ☹️
Edited by awlieser
    the uploaded image shows the advance tab of a WallPlug.
    There is no Chart available.
    Before the update it was.
    Before the update the folowing piece of code works
    104  local function powerConsumption(DeviceID)
    105    local jsonListe = api.get("/energy/"..startperiod.."/"..endperiod.."/compare/devices/power/"..DeviceID)
    106    return (jsonListe[1].kWh)
    107  end
    after the update getting an error:
    [SCENE241]: (load):106: attempt to index a nil value (field '?')
    hope this helps
    any suggestions or fixes
    Please contact support, we need to diagnose this locally - we cannot reproduce this on our side.
    As from wizzards hand, after 6 days of not working, now it is.
    Do you have an idee how this is going?
