I am using a module with HC3 and connecting the fase on it and I want to turn on and off using another module. Is it possible? Is there a parameter to configure or do I have to create a scene for it?
Thanks in advance,
@BarbaraLHi you can use assozations in order to turn on/off zwave devices without scenes. Look
and
  • 1 month later...
    and
    Sorry for the big delay here, but it worked. Thank you very much
    Edited by BarbaraL
    @BarbaraLYou're welcome.
    • 1 month later...
    Hi, sorry to ask you this now, I make the association work but I am wondering what each endpoint means, do you know? For each selelction, I have a different number of groups available. Is this each node or each device connected at z-wave network?
    /monthly_2023_05/image.png.2cbd2bad8d5b5e5c6a760dba852a8dbd.png" />
