In cerda 0
The keypad has wakeup set to 240s. If I bring it near the HC3, it works ok, if i use bell button after PIN submit, works fine, but i need to send PINs code from HC3 cloud interface.
But, in the final position, it must communicate through 2 Aeotec extenders. This keypad must accept the generation of temporary PIN codes. When adding a new PIN code, it displays Waiting for wakeup, then (after 240s or more) the code is not transmitted. If i click Syncronize, it remains stuck in synchronization animation. Configuration say: Device configured.
Are there solutions to solve this problem? Thank you
