Hello
Can we somehow inform user, if Quickapp device has been disabled?
Like print it on some label on QA's interface.
Problem is, that i can't make it by any code, as the code is not run, while device is disabled..
Is there any workaround?
You could build a QuickApp that checks now and then which devices are disabled and show them in the label of that new QuickApp.
    Thanks, yes i know that, but i was looking for some solution, that can be used on the Quickapp itself, internally, and not by checking from another quickapp.
    But probably this is not possible,  as device is disabled, so there is no way to interact with it.
    Ah, ok
    You can see it in the debug log when the QuickApp is being disabled with this code in onInit():
    You could add some other code to show it somewhere else.
    1 minute ago, SmartHomeEddy said:
    Ah, ok
    Yeah, but how to cacth it? How to cacth, when this DISABLED state occours.. Does it trigger some event? Ot how else to cacth it from inside the quickapp. Should I listen in a loop to the ENABLED property change??? But if I do so, and the quickapp gets disabled, my code also stops working...thats the point...
    If the QuickApp runs and you disable it, it starts the onInit() and you catch it with this code.
    BTW without this code, the QuickApp still runs.
    yes, but @Neo Andersson uses fibaroExtra, or? that code intercepts onInit and disables the QA, like in your example.
    yes i am using Fibaroextra
    ok, I pushed a new version of fibaroExtra v0.957 with a fix.
    define the function fibaro.__disabled and it will be called when the qa is disabled. there you can set a label or something in the qa ui.
    Great..thanks
    1 hour ago, Neo Andersson said:
    Great..thanks
    Jan, when i disable the QA, it still reacts to button clicks. (ofcourse throwing some errors, as all the variables are not loaded)
    Is this normal? I mean, is it normal, that user can still click on buttons and functions are called on button clicks?
    Edited by Neo Andersson
    Yes it is. You need to redefine action and UI handler to not accept any events.
