I wish to use a binary switch as a push button.
So when I press the switch becomes active (green) and after 5 seconds it automatically turns off again (red).
Can someone help me improve this code.
A universal binary switch with adjustable shutdown time would be a useful addition as a quickapp.
This code works, but without delay.
function QuickApp:turnOn()
    self:debug("binary switch turned on")
    self:updateProperty("value"true)
    print "hello" -- here some time delay code???
    hub.scene('execute', {[1] = 433, })
    self:debug("binary switch turned off")
    self:updateProperty("value"false)
Thanks.
9 answers to this question
You could add some sleepytime
fibaro.sleep(30000)
Thanks.
If i am not wrong, there are multiple options for this. I suppose you use HC3..
Option 1:
Most of the binary switches allow to set some Auto off functionality in parameteres. If you are using Fibaro double switch it is parameter 155 and 156 for outputs 1 and 2 respectivly. There you can set the Auto off time of the device. Meaning, that after a turn On situation, device waits the given seconds, then automatically turns off.
Option 2:
Use settimeout in Turn on function.
Edited by Neo Andersson
    Thank you for this info. I go try option 2.
    This works:
        self:updateProperty("value", true)
    function QuickApp:turnOff()
      hub.setTimeout(5000, function()
      self:turnOff()
      end)
        self:updateProperty("value", false)
    On 3/14/2023 at 4:32 PM, michelds said:
    This works:
      self:turnOff()
      end)
    Just a little side note....lines self:debug("binary switch turned off") and self:updateProperty("value", false) should be placed inside the settimeout function like below.
    Thanks for the info. I've only recently started testing out Lua, and small scripts like this are always welcome.
    I still haven't understood the mechanism of quickapps, and the explanation on Fibaro's site is rather vague for a non-IT person.
    Try:
    And if you want basic stuff explained please send me what in a PM. Maybe I'll write an article for it to help you and others. (or post your questions here on the forum).
    Edited by Joep
    Bedankt Joep !!!
