Hi. From some time new releases have information about light temperature adjustment being added.
But this seem not to be working - I have 18 Ikea bulbs (no color, just brightness and temperature regulated).
But I can only set the brightness - no option for temperature whatsoever:(
Have you removed and added devices again to the system as stated in changelog?
    Hey. Yes I did - not all of them but two just to test it.
    They were added the same way as before : Role - Light, Category - Light, Type - Multilevel switch
    Only On/Off/Brightness
    Could you provide exact model of the bulbs you are using?
    Sure. Model number LED2004G8 - This is Ikea Tradifri E27 806 lumens
    I will consult with developers and get back to you :)
    Super, thank you
    We verified this on the same bulp internally and everything is working as supposed.
    Please contact support, mention that we discussed this on forum.
    They will arrange remote access session and we will check it out on your system.
