Hi.
 The given code works.
  Please tell me if it is correct to deactivate the scene in this way?
 Task - when turning off the TV, which is connected to the network via the Fibaro Wall Plug, a scene should be activated that will complete the task and deactivate itself. Scene activation occurs according to the condition of consumed energy { conditions = { { id = 108, isTrigger = true operator = "<", property="power", type="device", value = 10 } }, operator = "all" } This scene sets the lighting brightness via Fibaro Dimmer 2 to 50%. Here comes the problem. Since the TV is turned off and does not consume power and the scene remains active, the light level returns to 50% even after manual adjustment to another level. This scene will be activated differently - by turning on the TV. Thank you very much.
Declarations
  conditions = { {
      id = 102,
      isTrigger = true,
      operator = "==",
      property = "value",
      type = "device",
      value = true
  operator = "all"
Actions
function fibaro.setSceneEnabled(sceneID, enabled)
 api.put("/scenes/105",{enabled=enabled})
fibaro.setSceneEnabled(105,false)
