Hi, I have a Fibaro dimmer 2 which is connected to a reactive switch, I would like the lights to be on dim at nighttime with the option of switching to 100% dim level in bathroom. I can set a scene for light to be on dim at night time but how can I set it so it’s at 100% when I want it to be whilst in bathroom, then when finished in bathroom if it’s during the night default back to dim for the night.
Can I use a standard pir to activate to dim level if nighttime with the option of setting to full brightness when switched from switch, if so I can told I do this.
I use a Vera Plus controller
