rsjabbens 1
Hi all,
I have a script to send a message when my garage door is opend / closed. Because the door is doing a close/open/close when closed i needed something to prevent sending multiple messages.
This is working, however the counter i have is not reset, so i changed a bit, but now i guess i need to have some loop to validate if it is closed for more than 60 seconds to reset some counters and prevent the counters for only adding 1 when opening/closing the door.
How can the scene be triggered by a open/close, such as it already works now, and in addition a time validation/loop when the door is closed for more then 60 seconds to reset the counters?
Ideally i want to add when the door is open for more than x minutes to receive some reminder, but this can be added later.
Any help is appriciated.
The script i created is added below.
Kind regards,
Roland
