Philips HUE (zigbee) setColor API syntax?
Trying to set a Philip HUE zigbee lights RGB value but I'm confused.
I have tried both:
hub.call(289, 'setColor', 5,200,255,0)
and
/api/callAction?deviceID=289&name=setColor&arg1=5&arg2=200&arg3=255&arg4=0
Both give the same result, theese values gives me the color: 56,199,255
What is going on here, is it not RGB values that are set with setColor?
Edited by Spett
    Anyone?
    Is there a bug in this update or have it always been like this? I have not used setColor before..
    The way it works now is that the values set with setColor are percentages of each other. (sort of, not completly tru but..)
    I mean:
    1,1,1 or 124,124,124 or 3,3,3 etc etc.. will always set bulb color to be 255,255,255
    10,6,2 will set bulb color to be 255,203,124
    10,10,4 will set bulb color to be 255,255,170
    Is it a bug or is it another color map?
    • Spett changed the title to Philips HUE (zigbee) setColor API syntax?
