Guys,
I have here a weird situation, which I don't really get.
I have a slider defined:
/monthly_2023_03/image.png.e94a5d5c5776dd5a5cc9d4c230a8dd0c.png" />
According to the manual I have defined a QA function:
But when I use the slider in QA, I get aan error, which I don't understand:
Can someone explain, what am I doing wrong? Thanks in advance.
Looks strange. You sure it's an uppercase 'I' and not a lowercase 'L'  in 'Intensity' ?
    I'm sure and to by sure, I've just copied the word from the slider parameters.
    I've solved it, by changing the name of slider from "Intensity" to "Int", but I still don't understand the issue.
    You had some strange character in the name - no problem with 9 character in the name.
