Hi there,
 I'm attempting to modify the work done by
 on the French forum, in which he's created a QuickApp to allow talk to MelCloud for Mitsubishi Air Con control.  In Australia and NZ, the equivalent service is MelView which has a similar but different API.  I have located the following works for the MelView API:-
.  But where I'm getting stuck, is seeing how to retrieve headers from the Http Response.  As you can see, when sending the inital login request, the resposne consists of a json table with data about the account, but more importantly, a cookie with an auth=<string> which is required to be passed in the header of future requests for the session.  I'm tearing my hair out, trying to find Fibaro API data that shows how to extract the response headers, and specifically how to obtain this cookie.
TIA.
Cheers,
Garrick
and then
Edited by marczu_83
