getselfid problem
This code isn't working
local selfId = fibaro:getSelfId()
fibaro:debug("SelfID")
I get "Unknown exception: /opt/fibaro/scenes/139.lua:7:attempt to call method 'getSelfId' (a nil value)"
I know almost no coding and googling has not provided a clue, nor chatgpt.
Does this code not work in your HC2? or is mine not well
4 answers to this question
local selfId=fibaro:getSelfId()
fibaro:debug(selfId) -- not SelfID
Edited by Bodyart
    No, not even that works.
    I got here because I was getting this error when trying to run something Sankotronic had provided to us. I tried pulling that bit of his code and testing it and looking elsewhere for a clean version of the above, just those two lines to simplify things.
    So this is the scene in total
    %% properties
    %% events
    %% globals
    But I still get this error [DEBUG] (error time/date - my words) [fatal] Unknown exception: /opt/fibaro/scenes/139.lua:7:attempt to call method 'getSelfId' (a nil value)
    Line 7 being -> local selfId=fibaro:getSelfId()
    Edited by MartW
    getSelfId() works for virtual devices, not for scenes. You didn't mention, that it is a scene you're using.
    For the scenes you can use:
    BTW For what do you need the scene ID?
    Edited by Bodyart
    Ah, so in trying to problem solve, I ended up using the wrong code for the area I was using it.
    I was getting an error code while following Sankotronics install instructions for a VD he had provided us, so thought copy/pasting it into a scene would help problem solve
    That code does work in the main loop of a VD. I can now go and try sankotronics VD again and at least have an example of code that I know does work.
    Thanks Bodyart, I may be one step closer to wherever it was I was going, lol
