10 temperature devices as Child device in a quickapp
I have 10 temperature devices (non zwave but 433 Mhz ). I get the data from a get request. I want to make 1 quickapp where all the devices are programmed as a child device .
My question is, is it possible to create 10 child devices of the same type (temperature device). If so with what of kind of function can I use the  updateProperty to update the temperature value in HC3?
5 answers to this question
Yes this is possible. Create a table with all your devices and loop though them to create them. Check
for great tips.
It can be overwhelming when starting into QA coding, so I give you some tips. This is an excerpt from my
To drill it down:
Says to the HC3 that the childs are created. This gives you the full manual control over the creation of the childs.
This checks if there are childs in the parent QA. If not (cdevs == 0) then create them, initChildData is a table to define your childs, in my example you see I use the same type in multiple childs:
After defining the childs a for loop creates the childs 1 by 1:
If cdevs was not 0 then there are already defined childs. While creating the childs you saved the className to use in a QA variable. This makes it possible to read the classes for already created childs and initialize them:
The classes are defined at the top of my QA, for example:
To update the childs you can simply loop though them and update the values:
Note:
You can download my
or reaD other community members their code to learn from.
I hope this sets you in the right direction. Happy coding!
    Many thanks for the elaborate answer. I am reasonable new to HC3 and lua but I look in to it and start trying.
    Is there a way to test my code without polluting my HC3?
    Yes, use the excellent
    from @jgab with ZeroBrane Studio.
    To get you up to speed fast
    Wow, this is exactly what I am looking for. I do have one question. Your code
    On 4/11/2023 at 7:20 AM, Joep said:
    Deals with the children in an all-or-nothing manner. I tend to be more of a pessimist in my coding so I wonder whether to approach this process as "Create the QuickAppChild only if it doesn't aready exist" and deal with each one when you loop through the list. Perhaps I might even go so far as to remove each child from my list. That way when I'm done initializing my current list, I could delete any QuickApChild which hasn't been properly initialized. I fear I might either add more children later or maybe delete the need for one and not remember to clean up after myself.
    I also want to say I looked around your site and found a wealth of other good material. I didn't subscribe to your newsletter. It would just get lost in all my email clutter and ignored.
    Thanks!
    Peter
    This is the easiest way to create children
    Put the library in a separate QA file. It defines a new QuickAppChild class that's named QwickAppChild
    It handles creation and removing of children automatically depending on the table given to self:initChildren(table)
    The trick is that all children should be given a unique identifier so we know if they already exists or are missing.
    In the example, it's the key in the child definition table. Ex. "Child_Temps1" for the first child.
