TRV keeps running calibration cycle
A few of my TRVs regularly run the calibration cycle, sometimes several times in an hour.  I've tried running one manually but that does not fix the issue.  What could be causing this?
These TRVs are on firmware 4.4 / 4.5, as I have no means of updating them.
Did you find the cause of this, I have the Z Wave TRV and it was working fine, then it started doing what I think is a calibration cycle, fully closes and opens several times an hour.  I did a full factory reset removed from my controller and set it back up and it has started doing it again for no reason. Driving me mad and it is losing the wife acceptance factor.
