yves.guern 0
I am using Z-Wave smart modules (Z-uno2) that are more or less based on arduino architecture.
They use an RTC component and I need to set its (unix) time, at least once.
During inclusion of the module in the HC3's z-wave network, a Command Class Time Parameters (0x8B/139) is sent by the HC3 and time is OK.
The problem arises when the module is reset (after power loss) the unix time setting does not occur.
Does someone know how to force the HC3 to send this Command Class Time Parameters ?
This is a sharp subject, I hope that someone can help.
Thanks in advance🙏.
