solved: failing HTTP-request to local HomeWizzard P1-meter on HC2
Guest Theo
Hi all,
I would like to register the readings of my P1 meter on a daily basis and retrieve them from the HC2 at a later time.  The raw data give much more information then the app that comes with the HomeWizzard.
I got it working for a Shelly lightbulb, but the Homewizzard keeps silent. Entering that url in any browser on any device does give me results however.
Also, a small program in Freepascal on my desktop does the job:
This gives results for both the Homewizzard and the lightbulb (partly shown below):
Quote
{"wifi_ssid":"MostlyHarmless","wifi_strength":30,"smr_version":50,"meter_model":"ISKRA 2M550T-1013",  (...)  }
{"wifi_sta":{"connected":true,"ssid":"MostlyHarmless","ip":"192.168.178.101", (...)   }
The code in my HC2:
Gives only a response for the lightbulb. Commenting out the lightbulb line does not make the difference (for the Homewizzard).
/monthly_2023_04/image.png.f458a1c942a8aa9ea2e6bfe29bdef76a.png" />
So the code is working just fine (although the code in FreePascal is much cleaner).
Thanks for any suggestions.
Edited by Theo
Typo
Guest Theo
    The HomeWizzard does send 1088 bytes of data. Is that too much?
    The stream of the Homewizzard in the Pascal program ends {after the last curly bracket} with four extra hexademical characters: x02, x00, x00, x00. Is that a problem? The lightbulb data end with the last curly bracket.
    • Guest changed the title to solved: failing HTTP-request to local HomeWizzard P1-meter on HC2
    Guest Theo
    I did some creative experiments to get results.
    Change url_HomeWizzard to http://192.168.178.10/api/v1
    In a browser this returns a html text:  "This URI does not exist"
    And some luck at last: I got this response in the HC2:
    Quote
    [DEBUG] 16:29:49: http://192.168.178.10/api/v1/:{}
    [DEBUG] 16:29:49: pong
    [DEBUG] 16:29:49: success for http://192.168.178.10/api/v1/
    [DEBUG] 16:29:49: encoded to json: {"status":404,"data":"This URI does not exist","headers":{"Content-Type":"text\/html","Content-Length":"23"}}
    [DEBUG] 16:29:49: ping
    For some reason the code handles status 404 as a succes.
    Next step: first send this request to the HomeWizzard and then one to the lightbulb.
    Result: the respons from the lightbulb is handled first and then the respons from the HomeWizzard.
    This suggests that there is some connection time-out when asking for a proper data response.
    So I added as header: Connection = "keep-alive"
    That does indeed the trick. Here the working code for the HomeWizzard, which also works for the Shelly.
    Still, in the output the Shelly will come first (data length and status in bold):
    Quote
    [DEBUG] 17:03:25: http://192.168.178.10/api/v1/data/:{}
     [DEBUG] 17:03:25: pong
     [DEBUG] 17:03:25: http://192.168.178.101/status:{}
     [DEBUG] 17:03:25: success for http://192.168.178.101/status
     [DEBUG] 17:03:25: encoded to json: {"headers":{"Content-Length":"714","Content-Type":"application\/json","Server":"Mongoose\/6.18","Connection":"close"},"status":200,"data":"{\"wifi_sta\":    (...)    }
     [DEBUG] 17:03:25: ping
     [DEBUG] 17:03:25: success for http://192.168.178.10/api/v1/data/
     [DEBUG] 17:03:25: encoded to json: {"headers":{"Access-Control-Allow-Origin":"*","Content-Type":"application\/json","Content-Length":"1084"},"status":200,"data":"{\"wifi_ssid\":   (...)  }
