irekk 5
Today, out of the sudden, I have received an email that Home Center 3 Lite device lost access to internet. This is a slave device so I have ignored that, but the user of the unit, started to complain, that automated scenes are not working.
I checked that on site and it turned out that any attempts to connect to three of wifi networks result with failures.
I went to recovery mode and resetted network settings and it give no satisfactionary results - results were the same.
Meaning two wifi networks returned error saying about conflicts and one network more generic error.
I went full ahead and did the full factory reset and now I'm getting errors in setup wizard. For two networks it results with error 425 and that one network result with error 502 and I cannot continue...
What to do now?
One thing to add: I don't know if that's common, because that's the only case where I used HC3L as a slave, but it crashes regularily every month or two for no reason. Stability of lite center is horrible.
Edited by irekk1 answer to this question
