Unable to re-link Fibaro in Google Home / Assistant
Daniel Alexandre
Grettings,
I've previously added all my Fibaro devices to Google Home using the linking procedure described in the site and everything went successful.
Today I had the need to unlink and relink the accounts so I followed the unlink procedure and used the unlink option in the Google Home, it went fine and all Fibaro devices stopped appearing on Google Home.
Right after I tried to link them again but I've been unable to do so. I click the link account, search & choose the Fibaro integration, it correctly opens the Fibaro Cloud ID page, I successfully login and can see my Home Center 3 listed, however I'm only presented with the "Open" button which takes me to the HC3 login page, there's no longer an Activate button as there was before, the Integrations just say "Active".
How can I recreate the association?
Thanks in advance.
Daniel
6 answers to this question
I've the same problem.
Best regards,
Josep
i have the exact same issue. Coming from HC2, where all devices where visible I migrated (manually due to migration failure) to HC3 icannot connect to any google home or IFTTT.
I can see the open button which leads to the fibaro devices but I am unable to activate.
Any suggestions
Beginning of the day did not work for me either. Now seems to work again.
After several attempts, I managed to connect HC3 (admin account only, no other account could be connected) to google home.
But what doesn't bother me is the connection of some devices. I have 2 identical devices (relay switches) and the 1st works and is connected and the 2nd does not work and is not connected. Both settings are the same in fibaro. Do you have any solution for this?
