Daniel Alexandre 0
Greetings,
I've recently bought 2 keyfobs and included successfully in Home Center 3, also configured some buttons to activate scenes when pressed.
I've now tried to set the lock/unlock option on both keyfobs and it doesn't work properly in either one of them. I followed the instructions and set the time to lock, a lock key and also an unlock sequence of 4 button presses. However after updating the parameters on the keyfobs locking them doesn't work, either timed or by pressing the key I've set, I can also press the other buttons and they keep activating the scenes as if the keyfob wasn't locked. I also noticed that after updating these parameters to set the lock code the keyfob will no longer respond to any parameter read/write, I have to reset the keyfobs, exclude them and re-include them to be able to use the keyfobs again.
Anyone knows what might be the issue of the lock operation not working?
Thanks in advance.
Daniel
