Is my Fibaro Door Sensor 2 dead?
I have a Fibaro Door Sensor 2 which was connected to my Fibaro HCL. A while back I removed the device from the HCL to add it back and re-configure it.
Since then I was not able to pair it to the Fibaro HCL nor Home Assistant.
When I click 3 times on the side button nothing happens. When I hold the bottom button and click the side buttons 3 times, it blinks 3 times and then stops.
I tried to reset it according to the Fibaro Manual, by holding the bottom button and side button and installing the battery. Once I do this it blinks a few times, but it does not blink 6 times after 30s to confirm the Reset procedure as the Fibaro manual suggest.
Is there anything I can do with it to repair/reset/pair it? Has anyone else experienced this problem and was able to fit it or is this a dead sensor?
