FGS_224: when toggling the physical switch, only one of the channels changes state
I have setup parameters
  • 1 --> to 2
  • 20 and 21 --> to 2
  • 162 and 163 --> to 0
  • 164 --> to 1
S1 and S2 and each plugged to the same bi stable physical switch (one on each output).
But when I toggle the switch, it turns off one of the outputs, but doesn't turn on the second.
See my hub logs - 3 tries and no event on Switch 2:
2023-05-05 11:23:05.405 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWave_Node_006_FGS_224_Double_Smart_Switch_1' changed from ON to OFF
2023-05-05 11:23:12.507 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWave_Node_006_FGS_224_Double_Smart_Switch_1' changed from OFF to ON
2023-05-05 11:23:22.002 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWave_Node_006_FGS_224_Double_Smart_Switch_1' changed from ON to OFF
Then I remotely turned on Switch 2 and tried again:
2023-05-05 11:23:41.037 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWave_Node_006_FGS_224_Double_Smart_Switch_2' changed from ON to OFF
No event on Switch 1
