How to make the Walli switch to only activate a scene, not the connected light with HC3
I am trying to set up a Walli switch with one connected light.
Out of the box, both buttons toggle the connected light by default.
However, I need the second button, to do a different action - activate a scene.
However it always does both, it seems I cannot disable the default action.
How can I set up the second button to toggle scenes only and not to control the connected light?
I am using HC3.
4 answers to this question
@pablooHello and welcome to the community.
The single/double operation mode has to be changed before including the walli switch to the homecenter.
You will have to exclude the walli switch from the homecenter. Than look below.
    Hi Fabir,
    thanks for your help!
    I tried the switch in both modes, however the issue still persists.
    Even if I allow scenes to be sent on 1 click on both buttons (parameters 40 and 41) and assign a scene, the switch always toggles its connected load. There seems to be no way to use the switch to control a different device without turning the connected light on?
    Isn't the switch supposed to only control scenes with 1 click instead of the connected light when the parameters 40 and 41 are set to 1?
    Did you find a solution?
    I'm running into the exact same issue where I'd like to be able to control either the load or a scene activation from the buttons
    worked perfectly for me. Removed the switch, changed the mode to single switch, then pair it again (without security but don't know why)... and then added scenario. It worked only when i turned on setting 40 and 41 to 2 (for 2 clicks)
