jluc2808 2
hello
pb 1:
- with Walli Controller (wired with 24v DC) i want to manage BSO managed by FGR223:
* when BSO reaches the top or bottom end i need to clic twice with delay (1 or 2 second) to perform an order (up or down)
* it's not the case (one clic) if the BSO isn't at end position
=> for this problem (2 clics rather than one) i never find a way to bypass the problem , If somebody have a solution or give me a way to bypass ?
pb: 2
- with Walli Controller (wired with 24v DC) and light managed by FGS223:
* when several Walli Controller are associated with the same light (same endpoint of FGS223) there is no synchro between them
if i enter a command (on or off) on one walli, the other doesn't know that the light has changed his state, so i need to clic twice to reset the right state.
=> for this pb i make a workaround with a scenario rather than association, but that doesn't satisfied my goal
any suggestions, help, report are welcome
