Guys, I have written the code below and The label alarmStatus label is never updated when the message arrives.
See below the logs. Any thoughts?
[14.05.2023] [22:43:37] [DEBUG] [QUICKAPP372]: onConnected: {"sessionPresent":true,"returnCode":0}
[14.05.2023] [22:43:47] [DEBUG] [QUICKAPP372]: event: {"topic":"riscopanel\/armstatus","dup":false,"payload":"disarmed","qos":0,"retain":true}
[14.05.2023] [22:43:47] [DEBUG] [QUICKAPP372]: Alarm Status: disarmed
-- Alarm partition type should handle following actions: arm, disarm
-- To update arm state of alarm partition, update property "armed" with boolean
-- To update alarm state of alarm partiton, update property "alarm" with boolean
-- Eg. self:updateProperty("alarm", true) will indicate that alarm partition was breached
function QuickApp:arm()
    self:debug("Alarm Partition armed")
    self:updateProperty("armed"true)
function QuickApp:disarm()
    self:debug("Alarm partition disarmed")
    self:updateProperty("disarmed"false)
-- To update controls you can use method self:updateView(<component ID>, <component property>, <desired value>). Eg:
-- self:updateView("slider", "value", "55")
-- self:updateView("button1", "text", "MUTE")
-- self:updateView("label", "text", "TURNED ON")
-- This is QuickApp inital method. It is called right after your QuickApp starts (after each save or on gateway startup).
-- Here you can set some default values, setup http connection or get QuickApp variables.
-- To learn more, please visit:
--    * https://manuals.fibaro.com/home-center-3/
--    * https://manuals.fibaro.com/home-center-3-quick-apps/
function QuickApp:onInit()
    QuickApp:EstablishMqttConnection()
    self.http = net.HTTPClient({timeout=10000})
    self:loop()
function QuickApp:loop()
    QuickApp:Subscribe()
    fibaro.setTimeout(10000function()
        self:loop()
function QuickApp:EstablishMqttConnection()
    local options = {  clientId = "Fibaro", username="xxxx", password="yyyyyyy", port = 1883 }
    local mqtt_server = "xxx.xxx.xxx.xxx"
    self.client = mqtt.Client.connect(mqtt_server, options)
    self.client:addEventListener('connected'function(event) self:onConnected(event) end
    self.client:addEventListener('message'function(event) self:onMessage(event) end
function QuickApp:Subscribe()
    self.client:subscribe("riscopanel/armstatus/#", { qos = mqtt.EXACTLY_ONCE });
function QuickApp:onMessage(event)
    print("onMessage:", json.encode(event))
    local alarm = event.payload
    self:debug("Alarm Status: ", alarm)
    self:updateView("alarmStatus""text""Alarm  Status: " .. alarm)
function QuickApp:onPublished(event)
    print("onPublished:", json.encode(event))
function QuickApp:onConnected(event)
    print("onConnected:", json.encode(event))
Edited by 03397
  • 03397 changed the title to Problem updating label
Does the label has the correct ID in the GUI editor? -> alarmStatus with the correct upper/lowercase chars?
    Thanks joep for your answer. I have found the issue and corrected it. The problem is the call of the functions inside other functions.
    For example I had
        self:loop()
    But it needs to be self:EstablishMqttConnection()
    I have corrected everything and and now everything works ok.
    Edited by 03397
