I have an somfy rts on off module and want to replace it with a fibaro dimmer 2.
As somfy works with a remote I need to install the dimmer prior to a dimmable electric transformer
Can someone help me with wiring it the right way
See picture
My thought is on a paint picture joined
Thank you very much :-)
Criss
PS there will be no switch (only Ok goole or app on the phone)
Edited by Criss
Things to consider...
  1. The Dimmer Manual is on line and you should follow the wiring in it
  2. You have the output of the dimmer connected connected to N instead of L
  3. You haven't connected what appears to be the earth
  4. You should consider whether an electrician is needed to get this wiring right for you
