Short circuit with the 1 - 2 wire connection
Hello
I want to wire a cealing lamp with a 3 wire cable. The wall switch should be a momentary switch with a connection to N and the other wire connected to S1 like in the picture on the manual (wiring diagram no. 1). When I have the bridge between N and Sx the is a short circuit and the circuit breaker cuts the power of.
What is the problem? How can I solve this? I have only three wires in the cealing. One for N, one for L and the third is the Wire to the switch.
Thanks for your help with this issue.
Edited by Aliasdispi
Correction
    Problem solved. The issue was the I made ab bridge directly from N to Sx at the controller. The Connection has to be at the second port of the switch. 1 port of the switch S1  the other port to N.
    Now it's working. The scamatics in the manual are a little bit confusing.
    I think you need to call an electrician to have a look at this for you.
