Hi there!
I've had this error several times now.
When you change the name when editing the scene, it does not save the new name although it appears a message of 'scene name changed correctly'.
Instead, you have to go back to 'Scenes' and change it twice.
It happens with scenarios as well as normal scenes
Maybe i'm the only one having this issue
Stay safe!
Yes, i am having this issue too. I have just noticed, that if you click the save button, then you click the activate button, then go inside the name box, and click out again,  (so kinda  save-> activate->save again) it used to work..
But anyway this is a bug too..I had not reported it, but i am pretty sure some other people did.
If I remember correctly it is fixed in new version.
