eureka 9
I'm using the TIME BASED EVENTS CONTROL lua scene from @Sankotronic (v.1.2.5) but since some time i'm having issues with it erroring out.
it gives the error that sunset is a nil value.
sunset is retrieved from deviceid1 using
most of the time this works normally, but every now and then it seems it cannot retrieve the value (while the global variable is actually filled). Anyone has any idea on why it sometimes cannot retrieve a value (and gets nil in return)? Also, how can I manage the error as it currently errors out and stops the script.
