Can not use or add Door sensors to HC2 after 1 year without batteries.
Hi all,
I changed home one year ago and put all Fibaro stuff in a box. Today I tried to put all to work again but I am not able to make door sensors work again.
HC2 is working fine with other devices. Just door sensors are unresponsive.
I replaced all batteries, for one, I tried to erase the device but I had to force the deletion and I am not able to add it anymore. For others, I just replaced batteries but nothing, death nodes.
HC2 version is 4.630, some door sensors are version 2.1 and some 2.5.
I tried to reboot HC2, as I told, one sensor I removed, other I tried to wake up but it is like HC2 can not see anymore the sensors.
Is there something else I can try?
Thank you!
Ale
5 answers to this question
@vantsHi you can try soft reconfiguration and wakeup the door sensors.
If this doesn't help, I recommend to start the exclude procedure on the homecenter in order to remove the sensors. Do this one by one and include to the homecenter again. For everey step and sensor, you need to wake up the battery powered device.
For the door sensor you had used forced remove, make sure this sensor doesn't remain in the controller as a ghost sensor. Sometimes several restarts / remove steps are nessesery.
The door sensor manual is
There is also a reset procedure for the sensor, but the exclude proccedure is reccomended
Edited by Fabir
Just to add
Factory reset sensor
Check with swagger file if he still exist if yes delete in swagger file
Succes
Edited by Sjakie
@SjakieHe has hc2 + hcl, where is the swagger in these homecenters?
Sorry long time ago I used HC2
remove with api?
Or I am mixed up I thought I did it in HC2 one device was still present or was it HC3?
Edited by Sjakie
    Hi all, thank you for all answers.
    At the end, the problem was given by batteries. I bought new pack on ebay, EVE brand. Maybe old stock…
    Anyway, I bought other set and all started work again.
    Ale
