Changing the "Use stored energy data in Energy Panel" in LUA code (to integrate it on a Scene) - HC3
Is it possible to create a scene in LUA that can change the status of the "Use stored energy data in Energy Panel" in a Device (HC3)?
I want to create a scene that select and a given triger from two meters to considera on the energy panel. I have booth configured on the Energy Panel, but sometimes (changing during the day) what to use one, and other times want to use another.
I manage to create a scene to enable and disable the device on Fibaro HC3, but i t seems that even when the device is disable, it continues to mesure the energy and adding it to the energy panel.
I've tryed some modification of the code "api.put("/devices/"..device_number,{enabled=true})" (what I was using to enable and disable), but cant' make it work... Is it possible?
Can someone help me?
    Thank you to @jgab!!! Amaizing!!!
    The solution for the device n. 653 is:
    4 hours ago, jgab said:
    saveToEnergyPanel is a property so
    api.put("/devices/"..653,{properties={saveToEnergyPanel=true}})
     Perfect!
