Tzim 0
Could somebody advice which from below options is better for connecting 24 V, 14.4 W/m, 9 m long LED stripe (white only, dimmable with led color 2700 - 5000 K, manufacturer Klus KWP-27/50-1440-24):
1. Using one Power Supply (for example Mean Well HLG-150H-24B) connected to RGBW Cont. and separating LED stripe to 2 sections (4.5 m each) connected to Out 1 and Out 2.
2. Using two Power Supplies (for example Mean Well HLG-60H-24B) and two RGBW Cont. LED stripe would be separated to 2 sections (4.5 m each) and connected to PSU/RGBW Cont. one and two.
Assume, that proposed PSU from Mean Well, will work correctly with Fibaro and will allow to dim LEDs and change their color.
Asking the question as I assumed, that I cannot just simply connect 9 m long LED stripe to RGBW Cont. Out 1 and RGBW Cont. to Mean Well PSU as LEDs at the end of stripe will not receive sufficient power.
thanks
9 answers to this question
