Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. New Z-Wave network diagnostic page
The Z-Wave network diagnostics page allows for the identification and resolution of potential issues related to the Z-Wave network.
What's new:
Access
    Redesigned the mobile device list under access settings.
    Access to newly added alarm zones, climate zones, and profiles is automatically granted to a new user if the "all" option is checked.
    Information when the last cloud service synchronization occurred is now displayed under the Users list.
    New selection controls for granting access to specific devices, scenes, zones and profiles.
Backup
    Performance improvements for backup list and status requests.
Devices
    Binary rain sensor is now available as an optional device for the sprinkler to prevent from watering.
    Improvements to device adding visuals.
    Added the ability to filter system notifications by supported notification channels.
    Improved support for the Aeotec Multi-Sensor 6 (soft-reconfiguration required).
    The camera preview tab is available only if a camera device has been configured.
    Improvements to Roller Shutter linked devices.
    Improved navigation for scene creation from device advanced settings.
Energy
    Improved selection menu for energy meter configuration under energy panel settings.
FTI
    Added information during FTI if user is not able to change Z-Wave engine version when some devices are already added to the system.
Other
    New tooltips visuals.
    Added a notification for automatic system restore in case of instability.
    Limited recovery loop in case of both systems failure.
    Hidden sensors can now be selected as primary sensors in rooms.
    Reboot is no longer needed after the first system configuration.
    Minor UX and UI improvements.
Profiles
    Removed redundant actions for Elero venetian blinds.
Quick Apps
    Improved auto-naming of QuickApp elements and labels.
Scenes
    Added support for custom thermostat modes to the block scene editor.
    Improved the "True for specified" time option setting for conditions in the block scene editor.
Update
    Added sorting the list of available updates for devices.**
    Hub update section moved to Settings → General.
    Device update section moved to Settings → Devices.
Zigbee
    Added default naming of newly paired devices.
    Updated general compatibility with devices on the market.
    Added possibility to force removing of not working Zigbee devices.
Z-Wave
    Stability improvements.**
    Improvements in "marking as dead" function.**
Bug fixes:
Climate
    Unable to edit climate schedules if a thermostat in that zone is hidden.
Dashboard
    Removed redundant buttons for multilevel switches from the sidebar.
    Permanent "Transfer Ok" caption on device tile for Elero devices in rare cases.
    Incorrect presentation of color temperature control for Zigbee devices.
Devices
    Fixed Z-Wave devices parameters values scaling after the "Reset all" action.
    Hidden tiles for the Smart Implant device no longer stay hidden in certain situations.**
    Qubino 3-phase meter has redundant tiles presenting voltage per phase (soft-reconfiguration required).
    FGT-001 setpoint graph not always correctly drawn.
    Downloading the device template loops in some cases.
Elero*
    Inversion settings for awning and pergolas does not work correctly.
Energy
    Fixed issues with generating a weekly savings graph incorrectly.
Gateway Connection
    Walli Controller configuration from slave gateway issue.
    Changing the description of the device added to the slave does not work.
    Setting favorite position for devices from slave gateway does not work.
Nice*
    After restart of the gateway system overwrites parameters for BiDi-Multi Sensor to default.
Other
    Issues with securely added devices before the migration to HC3.
    Addressed database overgrowth issues.
    Corrected language version for status messages in Recovery mode for selected scenarios.
    Fixed password character count validation to 10 characters.
    Remote access granted to support extended to 14 days.
    Minor UX and UI fixes.
Plugins
    Added RTSP stream support in web UI for Dahua plugin.
Scenes
    Addressed issues with lua scenes on autostart that didn't work in selected scenarios.
    Fixed control for Fan Modes in thermostats when triggered from block scenes.
Update
    Next device target can now be updated from a file without reconfiguration.**
    Fixed a bug producing incorrect status of the first target file during an update for a sleeping device.**
Zigbee
    The Philips Hue color setting when device is turned off does not work.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
    Gateway connection is not available in the new Z-Wave engine version.
*  - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
