Instead of redirecting me to Homepage I got 404 after starting services. In URL appeared following <IP_Address>/404 (e.g. 10.42.0.1/404).
This happened to me on 2x HC3 and 1x YH. All on different network.
Probably caused by Update page moving to settings and HC/YH tried to move me to page I was before update.
Another notice after update
Starting a soft reconfiguration of Aeotec 6 and Aeotec 7 sensor fails. Prior to this reconfiguration process, the device was fully configured and functional, and now remained unconfigured.
@Jakub.jezek's above mentioned error occurred for me too.
Edited by Neo Andersson
404, yes - we know about that minor issue.
Next beta will resolve this.
@Neo Andersson , could you download logs and send them to me please?
We will check them out. There was no changes on that part of the firmware so I really would like to see them.
I have restored my previous backup..does this matter for you or the log will  be still usable?
It should be :)
25 minutes ago, m.roszak said:
It should be :)
2 hours ago, m.roszak said:
It should be :)
Michael, I downloaded update again, just to see what problems occur, so i can send you info and help fix the issues.
So here is a thing, that i can't get my head around.
When I downloaded the beta first time, I swear to god, there I had a notification, that there is a template available for Danalock door lock...That is for sure..I downloaded it, and it got to a state, that system is waiting for Danalock's
wake up.
Later I had to restore the backup, because of the forementioned problem with Aeotec sensors.
Now, i downloaded the beta again, but now there is no template for Danalock...
How can this be possible?
(and ofcourse i doublechecked my Danalock, to be sure it still hasn't any template)
Can you please explain, how is this possible?
THanks
Another issue.
Opening any temperature sensor's general tab with the graph, throws error
Have you downloaded the logs? Could you of not?
As for danalock, there was no changes on templates regarding those devices - I will check im the logs you provided if there is something there.
You have the logs above in some of my answers
I meant after discovering error 500 :)
PM send.
PM send.
No. I dont have logs after 500 error. However, this error is already dokumented in some earlier tickets in Support chanells. It is a long time that i have reported it..ticket 260952
I swear i have downloaded the template for Danalock...
