After a while finally we have a primitive real diagnostic on the system... It's fine hope will be improved with some new functionalities but now at least we have one...
Any chance to have the possibility, for certain devices, to add a preferred routing path? Would be really userful on certain situation
We are planning to introduce in the future improvements in this diagnostic panel, I am pretty sure that it won't contain manual setting the routes for the nodes.
Maybe is some advanced Z-Wave network settings, even if - not in near future.
as for
I am not sure how to respond to this, is this an encouragement or not ;)
    as for
    yes it is :-D
    I guess that could be useful to add, in addition to this panel, a routing panel. This could be useful to understand, in case of an high error trasmit rate, what device are involved between the device itself and the gateway.
    Actually last working routes and neighbors is something definitely on the list to do in the future :)
    in my installation I have a device, a smart implant, that is placed in a bad place and the signal was not stable / good.
    I then realized that a repeater was necessary and as soon as I installed the issue ( loosing event ) was drastically reduced until almost zero.
    With this update unfortunately seems to be again not stable as it was, with old release I had no issue for months. I already tried several time a complete zwave mesh reconfiguration without improvement.
    Is anything changed on routing / path selection on this build?
    Raffaele
    Back on the last stable release and the issue I had seems to be solved.
    I don't know if the was some mods on routing / path selection but in my case the beta doesn't work well
    @m.roszak Do I have to check better on my side or something is changed on beta?
    Edited by Fyase
    Nothing has changed in routing between those versions...
    I have one thing in mind, during the update gateway chip is powered down for some time and devices cannot reach it - it is possible that on protocol level routing has been altered a bit and it should fix itself up after several minutes.
    In general, we do not alter the routing settings in any way - we never done it in the past. This is something which is maintained by the SDK automatically, it is possible to trigger neighbors update manually from the settings by user interaction.
    Ok, thanks. I'll check again on next build....
    I have done several zwave mesh reconfiguration with no improvement ( on beta ), with older version at first zwave reconfigurazione was back in order.
    Raffaele
