I can't login anymore. afther the upddate.
After this update, I cannot log in locally with the correct local-ip address. i get the message "Error, the HCaddress entered is not valid".
is something changd?
Use Fibaro Finder to see if it finds your controller
    ?? Fibaro finder on my IPhone? I don't understand, sorry.
    As I said, the IP address is correct. On my PC, at that address, the Fibaro app opens.
    But on my Iphone, the Mobile Yubii app no longer works with that local -ip.
    Before the update, it worked fine.
    In Yubii you don't use local adres you login with email and password.
    At home on your pc you login with local IP
    Outside home on your pc you log in with cloud
    Your question was't clear for me you did't mention IPhone
    succes
    It can be the case, like i had in the past, when my internet went down...
    Sometimes mobile phones doesn't allow local IP connection without having internet access. That was an absolute new information for me when i have heard about it, For me it happened, when my Internet was down. So i could login locally from PC but couldn't login locally from mobile. I don't know why is this, neither where, and what mobile settings is that, it was told by my friend, who is more experienced in mobile phones.
    So check if you are on internet on the phone..and if you are not, try login again with a running internet. If it works, than my friend was right.
    I use Yubii local login on one of my Android phones. No problem with version 1.19
    succes
    Sorry sjakie, I should have been clearer.
    But it's about the iPhone app, latest update. I log in with local IP address on this app for security reasons. I have no cloud connection because of that. Thanks for thinking with me.
    I had already reset the router and iPhone, nothing helped. until yesterday spontaneously everything works again. and I see that there has been no update of the app. another mystery. but it works again. thanks again.
    Thanks for your help Neo,
    I had internet, I'm sure. but it must have been something like that. Because without app update, everything works spontaneously again.
    Alex, thanks for reporting.
    Since yesterday my local login is working again. I don't know what happened to the app at the beginning of this month and that doesn't give me a good feeling. But on the other hand I am glad that it works again.
