Yubii Home Centre iOS 1.19 gives blank white screen
ewenjc
My phone upgraded the Yubii Home Centre iOS app to 1.19 and now each time I try to use it, it shows the normal page for a fraction of a second and then goes to a blank white page, so I can't control anything.  I've restarted the app, restarted my phone, reinstalled the app; but nothing changed.  I read somewhere that dark mode was a factor previously; switching off dark mode made visible some of the phones icons (battery, time etc) which I couldn't see in dark mode but the app is still unusable.  I have HC3 on 5.140.17.
Anyone know how to fix this issue?
Hi @ewenjc
We got this issue already reported and working on fixing it. So far the only workaround is choosing quickly the Home tab while the Favourite tab is loading. This way you can control your home until we find the solution.
What can I recommend so far is to temporarily change the start-up view by editing the navigation in application settings (move Home tab to the top). Apologies for the inconvenience.
May I ask you additional question: do you have the temperature schedule configured? If so, what devices do you use? This may confirm our diagnosis.
  • Hi @M.Grajczak
    Thank you for the update.
    The workaround has got me into the app.  Thanks.  In case others are trying the workaround; I did need to switch off wifi which slowed the load enough to click on Home tab before the white screen.  With wifi on it was too quick.
    I use Climate schedules and have the following devices connected; Danfoss thermostatic heads, Horstmann Controls thermostats & thermostat switches and one Fibaro multi-sensor.  Hope that helps.  Let me know if you need more info on my setup.
    Hi all … any news on how the fix is progressing. I have this problem also. I also have a heating schedule.
    thanks
    Mal
