The scene was always woking correctly in the older version for my garden watering system. After firmware update the delay timers aren't working correctly.
I have three sections for my garden and every 30 min it should go the the second section. Now runs just the first section (30 min) and the pomp stop's.
For each step I made a push message and I get all messages of all steps after the 30 min at the same time. So, the scene runs, but deny the delays by every step.
Of course it's possible to change the script (LUA), but it should runs like in the older versions.
@MinimensHello and welcome to the community.
Just to be sure, do you mean the latest beta relaease 5.141.59?
On hc3 and hc3l, I've seen the same issues. I've startet "Reconfigure Mesh Network". Look below. This seems to help in my case. I'm not sure, if the issue is solved permenantly.
  • 3 weeks later...
The only way for me to get it working was a convert to lua and change delay to sleep.
  • 5 months later...
I think I've figured this out (or at least have solved a similar problem).
The delay created in the UI only applies to the actions within the delay block.  If you put three sets of delays in a row, they don't run in turn - they run together, delaying the actions within them from the same starting point.
Look at the lua code generated if you turn it into lua, and pay attention to the brackets.
Paul
