HC2 & HCL Syncronisation issues with Smart Implant
Hey guys, A customer has a HC2 and HCL gateway connected, have been working fine for quite sometime.
I have come across an issue with a smart implant input status where it is not getting synchronised over to the HC2 from the slave HCL. (Status works perfectly on the HCL). If I manually synchronise the gateways, the HC2 gets the status of the implant but only once.
I found the slave gateway to be on a different firmware with release notes mentioning a fix for synchronisation between gateways. Both gateways are now on 4.630 but the issue persists.
Forums show a few others with the same issue but no mentions of a fix.
(Also finding a couple roller shutter relays positioning not syncing over the the HC2 correctly either)
Any ideas as to what might be happening here?
I have the same configuration and sometimes happened to me the same as to you.
Please try this simple action:
- restart slave (from web interface)
- wait until slave restart finished
- restart master
