Scene activation by double click on switch
smartgest
Hello
Please help me.
I want to start a scene when I double click on this switch
/monthly_2023_06/139769546_Screenshotfrom2023-06-1222-49-46.png.8ec0e3d9bb7702c892cb3596bea2e776.png" />
I set up the Parameter 28
Then I write this code:
Scene won't start on single, double or triple click. Start only when I click "Start"
Edited by smartgest
HC2 been a while, but 324 CentralSceneEvent must have the id of the parent "remote" and not the switch in HC2. Is 324 this id?
  • I try with all ID from 320 to 324 but no success to activate a scene.
    /monthly_2023_06/761549084_Screenshotfrom2023-06-1412-51-52.png.90bfe8119f24bb8ccb211618f41bb464.png" />
    322 is the parent of 324 but not working
    ID 324 is type com.fibaro.binarySwitch
    ID 322 is type com.fibaro.remoteController
    Edited by smartgest
    In 2017 I investigated a similar issue reported by another user. We concluded that the model owned by this user has a weird problem: Central Scene Event does not work reliably if the module is "far away" and uses a routed connection. I cannot say from the info in this topic if the type and firmware is exactly the same....
    What I would do is exclude the module, bring it to within 3 meter of the controller and include it. Set the parameters en test if events are reported reliably on one of the slave devices. If that works but stops working as soon as you move the module to its original location, then you are bitten by this bug described in the post from 2017
