MIKEsome 0
Hi
I have HC3L with 4 MCOHome MH7-WH thermostats
There is "standard" issue with those thermostats that clock is rushing (like if you set correct time, then in next month or so, it's showing +3 minutes vs proper time)
What helps is "soft reconfiguration" of device from HC3L setting, which sends set_time signal to thermostats and time display gets back to current one on thermostats, but after a month again time is wrong and I do another soft reconfiguration, and after a month another etc.
I'm wondering if there is an option to create some kind of script or event to "soft reconfigure" periodically?
Like once a week automatic soft reconfiguration would happen and I can stop doing this manually
Edited by MIKEsome5 answers to this question
