scene starts a scene in another HC2 with error message
a scene starts a scene in another HC2 with parameters.
Data are correctly received, but there is a strange error message.
Lua program:
  ip_port= "192.168.xxx.yyy:80"
  idSz= 194
  daten= "Hallo, hier Sender um "..os.date("%H : %M : %S")
  jDaten= json.encode({args={daten}})
  print(jDaten, #jDaten)
  http= net.HTTPClient({timeout= 5000})
  http:request("http://"..ip_port.."/api/scenes/"..idSz.."/action/start",
  { options=
    { headers=
      { ["Content-Type"]= "application/json;charset=UTF-8",
        Accept= "application/json;text/html",
        Authorization= "Basic cm.....",
        Connection= "keep-alive",
      method= 'POST',
      data= jDaten,
    success= function(resp)
      print("Resp.Status:",resp.status, "; data("..#resp.data..")")
      print(json.encode(resp))
    end,
    error= function(err) print("# Err:", err) end
Debug window:
[DEBUG] 17:45:27: {"args":["Hallo, hier Sender um 17 : 45 : 27"]} 47
[DEBUG] 17:45:27: 2023-06-14 17:45:27.408903 [ debug] Detected chunk with zero size, terminating connection
[DEBUG] 17:45:27:
[DEBUG] 17:45:27: Resp.Status: 200 ; data(0)
[DEBUG] 17:45:27: {"data":"","status":200,"headers":{"Cache-Control":"no-cache, no-store","Connection":"keep-alive","Date":"Wed, 14 Jun 2023 15:45:27 GMT","Server":"nginx\/1.8.0","Transfer-Encoding":"chunked","Content-Type":"application\/json;charset=UTF-8"}}
without   Connection= "keep-alive"   data are received correctly.
But now the error function is called and there is another error message:
[DEBUG] 17:48:24: {"args":["Hallo, hier Sender um 17 : 48 : 24"]} 47
[DEBUG] 17:48:24: 2023-06-14 17:48:24.959364 [ debug] error reading from socket: End of file
[DEBUG] 17:48:24:
[DEBUG] 17:48:24: # Err: End of file
Who knows what to change or an additional option?
Thanks in advance
Lua program:
  idSz= 194
  { options=
    { headers=
      method= 'POST',
      data= jDaten,
    end,
Debug window:
[DEBUG] 17:45:27:
[DEBUG] 17:48:24:
Thanks in advance
looks like timeout issue. You can increase the timeout or just ignore the error.
    thanks for your proposal
    hopefully I changed from 5000 to 15000, but even with 500000 no change
    so I'll ignore
