I installed the update after it was released and everything looked good at first. Today I wanted to do a backup, but neither local nor cloud could be done. I even tried rebooting with power disconnected. The backup process starts, seems to be running, but no files are transferred and saved. The backup list does not add the backup.
The same problem for me. Backup process starts and after then controller rebooted.
We will check it out, thanks for the report.
Any news in this case?
  • 1 month later...
@m.roszak any news?
How we can do backup now? My last backup is 1.5 month old.
How we will do required backup before next update?
I think it's a critical problem.
    You can write to support and they can resolve it by remote support.
    Ok
    Edited by Ekenswe
    We know what the issue is, support can help remotely but the fix is coming in the next release.
    • 2 months later...
    Hi @m.roszak, is it safe to update to 5.142.83 without backup ?
    Because making the backup fails the update process hangs.
    You can’t make a backup (without the update)?
    That is a rare issue introduced in 5.141 beta.
    Perform the procedure as in the pinned topic:
    Your current configuration will be backed up in a secondary system after that, so it is safe.
